First post, by Marco
Dear,
I thought I am not that stupid but I can’t get that new card run in:
DOS:
- config tool successful including DIAG
- msclient driver loading successful
- initializing tCP voa DHCP: FAIL. System just won’t continue. No time out nothing. Worked directly before with 3com cars perfectly. Also after deleting dhcp file of msclient - same result.
W95:
- installing card manually by provided drivers (2.0) successful
- after reboot: FAIL: card not installed correctly pls reinstall with correct driver
- after deleting all NW cards and using Hardware-Search: search finished without new hardware found.
Do you have any ideas? 386SX is the system.
BR and thanks
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 1 of 4, by Horun
Curious what IRQ and Port are you setting the NIC at ? Default port for most ISA nics is 300....
Reply 2 of 4, by dionb
Win95 on a 386SX...? Should theoretically work, but having been tortured with Win95 on a (much faster) 486DX33 at uni, I can't imagine why you would want to even try that.
That aside, how about starting with the basics - as Horun asks, it would be good to know which resources your card is using, and to double-check nothing else is (a lot of SCSI adapters default to 0x300 and MIDI can also be set there, even if 0x330 is more common).
Also, MS TCP client is a bit heavy. What happens if you use packet drivers and mTCP's DHCP.EXE?
Reply 3 of 4, by Marco
Sorry and thanks.
All configs worked flawless before with my 3com905b.
Base is 240 Irq is 10. all no problem before with the 3com and I configured the same values with the intel. Exactly the same 😒
Ps: there are no resources double allocated
Reply 4 of 4, by Marco
I won’t loose the feeling that it’s a card issue. Maybe not 386 compatible? All docs show yes.
I just reinstalled my 3com - no problem. I also noticed that windows hardware-search won’t find that card neither but when I manually add it it will show a window with proposed hw configs before proceeding to install drivers. See screenshots. This didn’t happen with the intel.
But again all diags results within the intel tool were fine
