First post, by douglar
- l33t
I've got an ST-138R Hard Drive
https://theretroweb.com/harddrives/1407
I found it attached to a Western Digital WD1006V-SR2 Controller
I put it on a 386sx motherboard and I figured all I needed to do was
1) Keep the same controller card
2) Keep the 1 pins in the right spots on the cables
3) Set up the drive in the bios with: Cylinders = 615, Heads = 4, SectorsPerTrack = 26
4) Turn on the power
The drive sounds like it spins up fine, but when the computer tries to access the drive after the memory count, I get a click-click-click-click-click-click for a couple minutes and then a hard drive error message from the bios.
Any suggestions? I'd like to get device drivers off the drive if possible.
