First post, by lo94
Hey all,
I was messing around making a MIDI application in Windows 95 in VB6 and was curious if there's an easy way to load SBI files into the SB16's instrument bank? Fairly new to this world and a bit confused if there's any higher level API or if I'd need to build out a .dll to pass it in
Thanks in advance for any info you can provide
Cheers
