PCEm and SLI Voodoo
First post, by Murdo
Hi folks
Trying to create an SLI config for PCEm.
No matter which motherboard/cpu I select, even select "no sound", I get an error on startup
"Failed to initialise PCI device '3DFX Voodoo Graphics' due to insufficient available slots"
Has anyone found how to get SLI working?
Thanks
Reply 1 of 1, by leileilol
You need a motherboard with enough PCI slots, and not use AudioPCI as that'll take a pci slot. Network cards can also take a PCI slot. A Voodoo2 SLI takes two slots
