Tiido wrote on 2025-06-30, 16:39:
The OSD chip is only an OSD chip, it doesn't contain the MCU that runs the show.
Yep, you're right. I was looking in the datasheet some more and was scratching my head why I only find text generation functions and not the video adjustments. Also, those 4 additional pins on the OSD position are the RGB output lines going to the CRT driver, I guess the other circuit variation could have blanked the controller and have the OSD output directly to the CRT driver. Anyway, that's mystery solved.
Tiido wrote on 2025-06-30, 16:39:Simplest way is likely inserting a pot into the video signal path, perhaps between the TDA4886 and LM2439 (pins 6, 7 and 9 are the inputs). Wires are gonna have to be really short or ideally none at all.
Yeah, I see a good place to add resistors or pots, but for a pot, what value would make sense here? 1K? 10K? Something else? I want this resistance between the output of the controller and input of the driver, or between the output of the controller and the ground?
There's a 390 ohm resistor to ground in the LM2439 datasheet reference circuit on each of the RGB lines, it looks to be absent in this circuit. Actual resistance of that net to ground is about 8.7K... If I divide it down, say to 5K on green, will that weaken the green?
I think I should look at the feedback reference voltage for each of the color channels on the controller, maybe there's something there to tweak. I'll look into the TDA4886 datasheet some more.
r00tb33r wrote on 2024-12-20, 09:02:If I turn up brightness all the way, the black of the screen glows cyan hue, meaning green and blue are strong.
I kept thinking about this observation, wondering if I should instead be boosting red, which would allow me to retain more overall brightness. I traced the RGB input from the VGA cable and only two resistors are present in the path, 33 ohm on the controller input, and 10 ohm on CRT driver input. These values are so small that I don't think (small) tweaks to them will have much effect. I did see a solder splatter blob right on the pads of the red signal path that flaked off with a mutimeter probe. I'm not sure if it was a solder blob from factory or when I was removing the shielding.
