First post, by boby
Hi all!
I got this Compaq Armada E500 (Intel 1 GHz, 256 MB RAM), for free, but without charger, HDD (and caddy). I have already ordered HDD caddy, but it will take some time to arrive. Charger I have also find and I managed to power on the machine, but there is some problem with it. It shows error like on the image bellow. When I remove the drive there is no error and I can boot from floppy disk. I have checked cd drive on some other PC and it works fine. Inspected the board and connector but can't see anything obvious. Cleaned all with IPA. I also update the BIOS but it didn't help. Now, I know that I have no HDD, but it should be able to boot from CD.
Am I missing anything?
Cheers!
Reply 1 of 3, by weedeewee
Just a guess.
The optical drive is a slave on the ide bus and the bios sees it as a fault that the master is missing.
Do not ask Why !
Reply 2 of 3, by boby
weedeewee wrote on 2024-12-21, 16:06:
Just a guess.
hm...could be, but there is no way to change this
Reply 3 of 3, by boby
So after I got caddy and installed it, everything is fine. No more error and cd boot works.
Very strange that it didn't wan't to without it. So for sure, was some master/slave issue.
