Privateer EMS ERROR
First post, by expyscho
My CPU is an intel 845gvsr, 2.4, 512 RAM, with an XP operating system. I get this error:
Error Code: D002-FFFF
Program Halted By Code
JEMM Unloaded
I've changed the ems, xms= stuff in the config file and tried the loadfix -1 solution, but i still get the same error. I 've been trying to play this game for 10 years and just found this program and the file, I would appreciate any help anyone could give me whether here, or by a link. Thanks. It's strange b/c i'm using .63 version of dosbox. :
Reply 1 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Use Privateers install.exe to configure the right sound card.
Reply 2 of 4, by expyscho
How do i know which sound card is the right one? I'm using realtek audio built into my motherboard?
Reply 3 of 4, by expyscho
Nevermind, it worked! Thank you, you are a god amoung men. thanks.
Reply 4 of 4, by HunterZ
Just a couple of comments:
- This is probably the Home of the Underdogs version, which (as mentioned) has a bad default sound config
- DOSBox emulates a variety of standard sound hardware that is supported by DOS games, and doesn't care what your real sound hardware is as long as it works in Windows.
