Heatsinks for Slot 1..
First post, by holdencars11
I got a whole lot of Slot 1 CPUs from a scrap e-waste pile (free). All the heatsinks were already taken off.
Are there any DIY or other alternatives for attaching a heatsink to these cards?
I was looking at the Zalman style GPU ones on AliExpress with the different mounting holes, and also some M.2 heatsinks that I might be able to modify....
Ryzen5 1600AF/ASRock B450Mac/16Gb/HD7750
i7 2600K/P67A-C43/16GB/GTX560
i7 960/MSI X58 Pro/8GB/8800GTS
Athlon II x4 620/GA-M56-S3/8GB/8800GTS
Duron 1300/A7S333/512MB/MX440
6x86MX PR200/PC Chips M571/64MB/ET6000
NEC PowerMate1 268 10MHz
And another 40 rigs.
Reply 1 of 16, by H3nrik V!
Even the plastic back plates are missing? ?
Reply 2 of 16, by holdencars11
H3nrik V! wrote on 2024-12-23, 06:07:
Yeah! PCBs only. And some are missing some resistors from where it looks like someone levered the heatsink with a screwdriver 🙁
Reply 3 of 16, by dm-
the only interesting cpu's are first and the last one, they're coppermines.
all other most likely a regular katmai/deshutes + 2 Klamath. check cpu's and if not 600 katmai or 400 unlocked deshutes, then just give it back to e-waste.
Reply 4 of 16, by analog_programmer
Slot 1 coolers are sold on the "fleabay"-dot-com. Another option is to make your own 3d printed brackets/adapters for regular s.370 coolers.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 5 of 16, by H3nrik V!
analog_programmer wrote on 2024-12-23, 09:05:
The problem is that they're all depending on the plastic backplate of the Slot CPUs. But I guess that something appropriate could be 3D-printed for that function ...
Reply 6 of 16, by analog_programmer
H3nrik V! wrote on 2024-12-23, 10:16:
Yes, there's always an option of something to be adapted or 3D-printed. But some models manufactured by 3rd-parties are equipped with their own retention bracket.
The attachment cm.jpg is no longer available
The main problem is with prices on the fleabay.
Reply 7 of 16, by AlexZ
Missing Slot 1 heatsinks and plastic backplates are not a problem. You could buy a few Socket 370 heatsinks (must be large enough) then use a pillar drill to drill 6 holes - 4 for bolting it to the PCB and 2 for attaching a fan. Alternatively you could buy original slot1 heatsinks and modify them the same way.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 8 of 16, by PARKE
That type of aftermarket cooler also needs the plastic backplate because the distance from fastening clip to PCB is wrong without it -plus- you cannot have bare metal touching the rearside of the pcb.
Reply 9 of 16, by analog_programmer
PARKE wrote on 2024-12-23, 11:50:
I don't know what this Cooler Master cooler kit includes. For the price that's announced it would be shame not to include some piece of thin plastic insulator, plastic washers, etc. parts needed for adequate attachment. The picture was just to illustrate the possibility to attach the cooler to processor's PCB without the original plastic housing of the processor.
Reply 10 of 16, by H3nrik V!
Exactly my point 😀
Reply 11 of 16, by H3nrik V!
analog_programmer wrote on 2024-12-23, 12:05:
Probably not - as it is designed for mounting on a CPU that has its original back side still mounted.
Reply 12 of 16, by analog_programmer
H3nrik V! wrote on 2024-12-23, 12:24:
Ok, picking 3rd-party cooler by pictures is going to be tough.
There are stock and aftermarket coolers for slot 1 (SEPP) celerons that mount directly on the PCB by their own insulated back-plate/bracket. These may be suitable if their mounting holes match those on the PII/PIII PCBs.
Reply 13 of 16, by AlexZ
Plastic backplate is unnecessary. You can bolt the heatsink directly to the PCB through holes drilled through the heatsink. You will need tiny plastic washers. You can pick 3rd party cooler by dimensions.
It's easiest to just buy one PIII heatsink.
Reply 14 of 16, by PARKE
analog_programmer wrote on 2024-12-23, 12:44:
The orientation of those holes is different between Celeron and PII/PIII
The attachment Untitled-1.jpg is no longer available
Reply 15 of 16, by holdencars11
I modified a cheap AliExpress universal Zalman style VGA heatsink that I had already. Holes in the HSF already align with two of the mounting holes.
Sanded off the bottom edge of the cooler baseplate for a better fit. Insulated the underside of the heatsink except the core contact area with kapton tape and then a plastic shim that I made.
I'm very happy with the result, seems to cool very well and looks great too!
Reply 16 of 16, by H3nrik V!
Boss move! Very nice!
