First post, by arncht
- Oldbie
This is my modern frontend, designed to seamlessly support any modern PC or Mac while also accommodating older machines. Due to space constraints, I can’t keep peripherals from different eras, such as CRT monitors. I switch between machines depending on which era I feel like exploring, and I can comfortably do my work here as well, mostly using a MacBook.
Currently, the DX4 setup is connected under the desk.
Samsung OLED G8 34” display
OSSC Pro scaler
Behringer Flow 8 mixer
iLoud MTM speakers
Roland SC-55 MIDI module
Roland MT-32 MIDI module
Retro fleet:
1987, Amiga 500, 1M RAM, Kickstart 1.3
1993, 486DX2 66, 8M FPM, WD90C33 1M VLB, SB Pro 2.0, MS-DOS 6.00
1995, DX4 100, 16M FPM, S3 Vision864 2M VLB, SB Pro 2.0, GUS 1M, Roland MPU-IPC, MS-DOS 6.22
1995, Pentium 120, 16M EDO, S3 Vision968 2M PCI, SB AWE32, GUS 1M, MS-DOS 6.22
1997, Pentium MMX 233, 64M SD, S3 ViRGE 4M PCI, 3Dfx Voodoo 4M, SB AWE64 Gold, GUS PnP 8M, Win95 OSR 2.5
1999, K6 III 450. 128M SD, 3Dfx Voodoo3 3000 16M AGP, Aureal Vortex2, GUS PnP 8M, Win 98 SE
2000, Pentium III 1000, 256M SD, GeForce2 Ultra 64M AGP, SB Live, GUS PnP 8M, Win 98 SE
2003, Athlon XP 3200+, 512M DDR, Radeon 9800 Pro 128M AGP, Audigy 2, WinXP SP1
2006, Core 2 QX6700, 2G DDR2, GeForce 8800GTX 768M PCIe, X-Fi Fatal1ty, WinXP SP2
