First post, by dreamblaster
Just released :
SF2 : a MIDI synthesizer that uses sf2 soundfont files
the software is based on MT32Pi, with a tweaked configuration for live performance
the hardware is based on Pi zero 2W + custom PCB
https://www.serdashop.com/SF2
it can be used for as sf2 synth
also for mt32 emulation (if you provide the rom files on the sd card).
Connectors :
  • Standard DIN MIDI input
  • USB-C connector for power (for 5V 2A adapter)
  • 3.5mm stereo line out
  • Micro SD card slot
The attachment SF2_frontal_wb.jpg is no longer available
The attachment SF2_rear_wb.jpg is no longer available
The attachment SF2_sideview_wb.jpg is no longer available
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 1 of 2, by kisscool
Received mine, and done some testings. Great device, as always.
Compared to the original MP32L, I really prefer this form factor.
Posted a little review (with sound) on my Instagram : https://www.instagram.com/keyser_p4g/p/DEcjq2sNZXm
Reply 2 of 2, by dreamblaster
Hi I did some further development, with a new SF2 panel
SF2 was intended to be used by musicians
I also made a new 'personality' for gamers : TM32
I will make a separate post for it
Both new panels use a trick i have been experimenting with, to create a good looking led glow logo.
--> see photo's, it looks even better in real life
TM32 will be the successor for MP32L
