First post, by Guld
I'm using a Shuttle HOT-419 motherboard https://theretroweb.com/motherboards/s/shuttle-hot-419, set up with a 486 DX4/100 MHz (33MHz bus speed).
Two different video cards, both with 2 MB of memory on them, are having the same issues.
Cirrus GD5428
Cirrus GD5429
I see similar issues with not getting a usable video output from both DOS and Windows:
DOS
- using UNIVBE, recognizes 2 MB of memory on both cards, using UNICENTR just to check the modes.
- Anything using over 1 MB of video memory produces an unstable image
- Also tried the Cirrus VESA drivers and X-VESA to try setting videos mode that use more than 1 MB.
- Same issues, video modes beyond e.g. 1024x768x8 do not work.
Windows 98SE
- Using PowerStrip, or the normal windows resolution setting tool, I can not get a good video output using > 1MB
- At first I thought it was using a vertical rate that my monitor didn't like, but I've selected the correct ones with PowerStrip and it does not help.
One thing I found that did allow me to at least use 1024x768 was setting the CPU RDY# Signal delay configuration to Setup 2 which is listed as "33MHz or 50MHz system clock with slow VL-bus devices". Without this set, max I can seem to do is 800x600x8. Not sure if it's related.
I've tried other jumper settings for CPU ADS# delay, and VESA Local Bus speed and high speed write wait states but those had no effect.
I've also tried a spare set of additional memory for the cards which doesn't seem to help. It seems unlikely that all 3 sets of video ram chips I have are bad, but I have no way to test them directly.
I've tried BIOS settings which seem like they might be related but saw no changes in the behavior.
Any ideas? I find it peculiar that 2 different video cards exhibit the same issues which makes me think it's possibly a motherboard issue?
Motherboard and RAM have been through >8 hours of testing with memtest86+ so I want to say the system is generally stable.
