First post, by Nunoalex
Hi
I was wondering if someone can help me with my Riva 128ZX AGP video card
It works well but it only displays monochrome (Black and White)
This is very strange because it is not a problem with a specific RGB channel as white supposedly uses all channels no ?
The card seems to be working well besides the monochrome... there are no artifacts or strange behaviors
I am thinking this could be some corrupt BIOS data on the card?
But unfortunately there is no BIOS file for this card on the RetroWeb
https://theretroweb.com/expansioncards/s/gain … rd-cardex-128zx
This is a picture of a similar card to mine
does anyone know about a similar situation ?
Thanx for the help
Nuno
Reply 1 of 4, by Imperious
Red, Green, and Blue all turned on at maximum equals white. So You do not have a problem with the RGB outputs.
What's the rest of the setup? Maybe there is something in the driver utilities that can be adjusted, although why it would default to Greyscale I have no idea.
Technically it's Greyscale, not black and white.
I have a normal 128 and a ZX128 in my collection but both worked no problems.
Reply 2 of 4, by BinaryDemon
Almost every time I see a similar thread, the issue is with the VGA cable. Have you tested the cable with another card/monitor?
Reply 3 of 4, by revolstar
I had a similar problem and the vga socket on my gpu (bent pins failing to make contact) was the culprit.
Win95 rig: Pentium II 400/64MB RAM/Matrox G400 16MB/Voodoo2 12MB/SB Live! + SB 128
Win98 rig: Athlon XP 2500+/512MB RAM/SB Audigy/GF FX5700
WinXP rig: HP RP5800 - Pentium G850/2GB RAM/GF GT530 1GB
Amiga: A600/2MB RAM
PS2, Ps3, Dreamcast
Reply 4 of 4, by Nunoalex
BinaryDemon wrote on 2025-01-02, 13:26:
OMG !
You guys are so good!
It really seems there is something wrong with the cable or the VGA connector on the card as I moved the cable and plug a bit and the colors did come !
It must be something on the card as I have plugged that monitor to countless other cards without issue.
I sprayed some deoxid and maybe I will reflow the 15 pins of the VGA connector on the card.
But there is still something wrong with the card as sometimes on windows there are some yellow or blue patches appearing, they come out when I resize the screen but they come back after a few minutes.
Thank you so much !
