First post, by vtech
Hello,
I'm currently fighting an old system, I can't find any information, it is a Mitac Mistation 3S 3052E, it is a 386SX-20 system, besides a tantalum blown on the first power up, I'm fiddling almost with bad RAM and an occasional keyboard lock, today the case was different, the PC doesn't start and no activity in the the post card, I have a temperature gun and I noticed the keyboard controller warmer than chipset and CPU, those two around 20 Cº and the keyboard IC at 34 Cº, I remove it and the PC came to life, albeit not displaying image, gave me some beep codes and there is activity on the post card.
So, my question is if I can replace this keyboard IC with other similar or must be the same, and if this is in some sort programmable, because it as a sticker related to the Phoenix BIOS in this system, because I have a dead motherboard, also from a Mitac system, but a 486SX, the difference being this one as a sticker related to the AMI BIOS. And I was wandering if I can replace with this one?
The controller is a Intel P8742AH / L1275363
