First post, by demyx
Hi everyone!
Months ago I bought a non-working IBM 5150, with some cards inside.
Over time I managed to fix the motherboard that was reporting errors on the memory, so I started testing the cards.
The IBM CGA gives me display problems as in the photos.
The visible defects appear only when the image is moving, for example while displaying the contents of a directory, while with a still image no anomaly is found.
I also tried the card with the Landmarks diagnostics, but the test passed...
Also tried on a 386sx, but the situation does not change.
Does anyone have any idea where the problem could be?
Thank you very much!!!
