First post, by Sharkspine
Hello
I have a Mitsubishi Diamond Pro 920 Monitor connected to my Windows 10 PC. I have started using DOSBox to play retro titles. The lowest resolution my Nvidia card can 'see' is 800x600.
I have used CRU to set up two custom resolutions following the timings specified from the'TinyVGA' website. My monitor has no issue displaying these. They are:
- 640 x 400 at 70hz (for Quake and Descent) with DOSBox settings to scale= normal2x / Aspect=False
- 640 x 480 at 60hz (for HOMM 1) with DOSBox settings Scale = none/Aspect=false
However I assumed when using these settings the display would be full screen i.e the whole game screen would fit 'corner to corner' however there are black borders around both resolutions at the listed refresh rate.
I am able to manually use the monitors in built controls to adjust the display to fit the screen and these settings are saved by my monitor whenever I want to switch with no issue
Are the black borders just how the display is supposed to look? And by utilising the monitors in built controls to make the game image fit is it still preserving the aspect ratio?
Thank you so much for your time and take care.
