First post, by Thrackerzod
I bought an XT-IDE Rev 4.1 from Blue Lava Systems about three years ago and have been using it happily in my Dell 386, until today when I had the genius idea to update the firmware. It always bothered me that the version I had said Beta and it was from 2015 with the latest from 2024 so it seemed like a great idea at the time. Except when I tried to flash it I got the error "eeprom did not return the same byte that was written" and the flash failed. Worse it now would no longer boot up to my CF card, but I could still boot to floppy disks so I figured I'd just put the original firmware I had on a disk, boot up and flash that. Except the flash failed again, and again, then it almost went through but now it's completely hosed. I can't even boot up to a floppy anymore, it tries but then asks for the location of command.com so I can't even try flashing it anymore. Unfortunately I don't have an EEPROM programmer so I guess I'm just up the creek at this point. What's the old saying about not fixing something if it isn't broken? Not sure where to go from here, this is so frustrating. š
