First post, by Jackhead
im thinking about get my PSU in my 5160 replaced with a ATX4VC to provite all the voltages for the mainboard.
On th ATX4VC i want connect a pico psu with 160W max and as power source a 12v 150W psu.
Anything should build into the old PSU case (the 12V power source extern).
But what is with the input board that also provite voltage to the monitor? Can i just connect my monitor (5153) directly to power cord?
Or should i leave the the input board installed for the monitor, for some magic filtering?
Anyone build something else before?
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 1, by Jackhead
since my old 5160 PSU died i replaced it with a ATX4VC with pico PSU and a 12v power source.
Anything fits in the old case and it works very well!
The attachment IMG_7933.jpeg is no longer available
The attachment IMG_7931.jpeg is no longer available
