First post, by FX506
I know this might not be a wrapper related issue, but it would be nice if you could look into it: V-Rally 1 crashes both in DirectX and Glide mode on the second stage of the England tournament right after you drive off from the starting line, but other stages don't have the same issue. It happens in every mode (Arcade, Championship, Time trial). I looked at debugview but it's normal until the crash, where it just reports an access violation. Putting the game into Win98 compatibility mode prevents the crash (the level is completable that way, therefore it isn't a game file issue) but it causes a crash when you finish a tournament and try to go back to the menu.
Reply 1 of 2, by Squall Leonhart
open up the windows defender options and add a profile for this game in the exploits protection section with control flow guard disabled.
Reply 2 of 2, by FX506
Tired it, didn't work, the crash on that stage still consistently occurs. Also the game seems more unstable overall, don't think it's related to the Defender settings though. Sometimes it crashes upon finishing a season, but sometimes it just works fine.
