Motherboard SBR247
First post, by Chopin66_1
Hello everyone and thank you for accepting me on the forum. My name is Patryk, I live in Poland.
I have such an interesting and not very common motherboard
The attachment 1000014684.jpg is no longer available
The attachment 1000014683.jpg is no longer available
The attachment 1000014682.jpg is no longer available
The attachment 1000014681.jpg is no longer available
The attachment 1000014680.jpg is no longer available
This is what I know about it:
-CPU: 486 Socket PGA168
-Fcpu: 66.6667MHz
-Chipset: OPTI 82C496-B1 and Siemens SAB 82C206-N - probably supports up to 64MB RAM
-4MB EDO RAM chip (8 x GM71C4400AJ-70 chips)
-Three 72-pin SIMM sockets with the possibility of adding up to 64MB - this is the theoretical support of the chipset
-Graphics on the WD90C30-ZS chip, 1 MB DRAM Siemens 4x HBY514256BJ-70 plus the possibility of adding 1MB to 2MB- 4 soldered sockets for ZIP and four free spaces, goldpins described as Video Feature, VGA and Hi-res SVGA output
-2x serial port (one on the board, the other on the goldpins), parallel port, AT keyboard socket, PS/2 mouse socket, Floppy Drive socket, Hard Drive socket.
-Motherboard from 1992.
The board is marked SBR247.
Google and The Retroweb are silent on the subject.
So I am asking for the identification of this board. Maybe someone knows who is the manufacturer of this board, where it was used.
If someone has the same board, would they be able to download BIOS to it and provide the EPROM/EEPROM model? and take pictures of the expansion card? I am missing the BIOS and the expansion card.
Best regards,
Patryk
Reply 1 of 3, by PC Hoarder Patrol
Chopin66_1 wrote on 2025-01-09, 17:29:
1 242 / 5 000 Hello everyone and thank you for accepting me on the forum. My name is Patryk, I live in Poland. […]
-Fcpu: 66.6667MHz
Best regards,
Patryk
Welcome to Vogons Patryk 😀
What you have is the mainboard from a Zenith Z-433DX AT Desktop, most probaby like this system - https://www.worthpoint.com/worthopedia/vintag … d-80-1786442442
In the attached parts list you'll see the mainboard listed as Z240-8124-10 BOARD ASSY 486DX 33MHZ and the ISA expansion riser as Z240-8140-10 BOARD ASSY BACKPLANE 5 SLOT
The attachment Zenith Z-433DX AT Desktop Parts List.txt is no longer available
Reply 2 of 3, by PC Hoarder Patrol
This looks like it may be the latest BIOS update, sourced from here - https://archive.org/details/ZenithDataSystems … ebsiteFiles1996
3044-13.EXE 202406 12-05-94 Flash BIOS - Z-Station ISA/Z-300/Z-400 V4.3D Self extracting compressed files - Uncompress to a temp subdirectory on hard drive, then copy to blank bootable floppy and boot clean (NO DRIVERS LOADED), and run reflash.bat. THIS BIOS DOES NOT SUPPORT ZUG-486 UPGRD KIT
The attachment 3044-13.exe is no longer available
Reply 3 of 3, by Chopin66_1
Thank you so much, that's it, you are great, thanks again.
