First post, by songoffall
- Member
My first desktop PC was a Pentium 4. It wasn't my first PC; I started with a Compaq 486 laptop, a Contura 430C, and was quite content with a DX4/8Mb RAM/Windows 95 setup and the only thing that bothered me was the lack of any sound outside PC speaker and passive matrix LCD, which made gaming on the laptop quite questionable.
So in 2002 I went to university, and had my first desktop PC, which was a Northwood Pentium 4, the 1.8A model, a Gigabyte P4 Titan533 motherboard with Intel chipset, 128Mb DDR-400 RAM, Sound Blaster Live! 5.1, and a GeForce2 MX200, which was actually seen as a high performance option, in comparison to what most other people had - Intel, SiS and S3 integrated graphics, and the SiS in particular was more a sentence than a GPU, and if you were lucky, you'd have a Riva TNT2.
A friend of mine had a Voodoo3, and that card was seen as a beast, and there were rumors of the mythical GeForce3 Ti none of us were able to afford.
I had a lot of fun with that PC until I replaced it with an LGA775 Pentium 4 build in 2005. By the end it had about 512Mb DDR with mismatched sticks I had scrounged, 128+128+256Mb, but it was well cared for.
I had the idea of rebuilding that system, but then decided to build something better.
My new build uses MSI 865P Neo - I'd prefer the 865PE, but this is what I was able to find - and a 2GHz Northwood Pentium 4. Unlike Athlon XP, Pentium 4 Northwood can be used with modern PSUs. Unlike my old system, I'm not planning to run Windows XP on it, so 512Mb DDR is plenty. As for the GPU, I'm planning to get a GeForce4 Ti4200 at some point, right now it's running a GeForce FX 5500, which isn't very good, but will have to do until I get the upgrade. The sound is a Creative Audigy2, and the HDD - a WD Caviar 80Gb 7200rpm - is on its way.
When I started up the build to test if it was functional, I was shocked to see that the CPU temp was about 60C, but perhaps the BIOS had a bug, because the heatsink wasn't that hot, and after a BIOS update the temp got to a more reasonable 40C, and after replacing the stock Intel cooler with a beefy Coolermaster it went further down to 30C at idle in BIOS. I have better results with my Athlon XP2000+, but that one has a completely custom cooling solution and a bunch of Noctua fans keeping it cool, and runs at a lower clock, so I'm quite satisfied with the cooling of the Northwood.
As for performance, I'll have to wait for the HDD to arrive. The Athlon XP/nForce2 combo was notoriously troublesome, with very rudimentary BIOS options, long boot times and device compatibility issues. I've heard good things and have good memories of Intel chipsets, so we'll see how this one goes.
Pentium 2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 2.0GHz/GeForce4 Ti4200/Sound Blaster Live!
Core2Duo Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
