First post, by majestyk
- Oldbie
I have a Chaintech "5HTM M101" ATX mainboard that seems to have a problem with it´s primary IDE interface:
While everything´s fine with the second channel - both manual and automatic harddrive configurations work as expected, on the primary IDE channel I get this:
I tried different BIOS versions, different harddrives, all kinds of resets, but the issue persists. Needless to say the system won´t boot with the respective HD, but reports "disk boot failure, insert system disk and press enter".
The HX southbridge "82371SB (PIIX3)" takes care of the 2 onboard IDE interfaces here.
Has anybody encoutered this or a similar issue before??
