First post, by eviljebus
I am trying to use a controller I have... it's a regular USB controller that is almost exactly like a playstation 2 controller. When I start DOSBox I get the message:
Using Joystick USB 4-Axis 12-button Gamepad with 4 Axes and 12 Buttons.
That sounds exactly right, but when I go to play games, Only 2 buttons actually work. I have tried multiple games and it is the same 2 buttons that work every time. Can anyone please give me some advice on how to get my controller to work?
Thanks,
EvilJebus
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
ever used dos ?
dos supported only 2 buttons 😀
gravis used a hack to get 4 buttons by stealing 2 buttons from joystick 2
Water flows down the stream
Reply 2 of 4, by eviljebus
Yeah I used to run descent on my 486 with much more than 2 buttons on my joystick...
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
then it was no default joystick.
anyway the cvs version of dosbox support some "weirder" joysticks
(like 4 button and one hat like thing)
look at the development forum for CVS builds. (you need to tinker in the configfile then as well a bit)
Reply 4 of 4, by eviljebus
ok thanks for your help
