First post, by amxcs
Hello, I want to ask if this game is possible to run under Winodws 98. I tried restarting from 98 under dos, but again it won't run. To make sure that the problem is not with my configuration (P4i65G + P4 + Radeon 9600) I tried the game with PCem and it gives the same error there.
I ran dos (from a bootable disk) and the game ran perfectly.
What is the difference between the 98 dos and the clean dos (from a boot disk)?
I also want to ask if the game has a windows version or is it "Black Warrior"?
