How do I go about transporting an IBM 5160?
First post, by alfiehicks
Hi, I've bought an IBM PC/XT online and I'm going to collect it myself. It's still got its original MFM hard drive and the seller showed it to be in working condition. I've heard that these drives don't park their heads when powered-down, and that there are programs that you can run which will move them back to their landing zones to prevent damage during physical relocation. The seller isn't very tech savvy, so I can safely assume that they won't have done this - and probably don't have a way of getting data on to the computer - so I'm considering bringing a 5.25" disk with the software written to it, and running that while it's still set up at the seller's house. An annoying complication, however: I don't own any other hardware from this era; the oldest machine I've got is a 486. I do have several 5.25" floppy drives, but they're untested as I currently don't have any disks. I know there's a lot of incompatibilities with the 5.25" format, with not all disks working with all drives, but I don't know much about the specifics, especially not with the 1.2MB vs 360KB and 80-track vs 40-track and all of that. My questions are:
Is there a general consensus as to which program to use for parking MFM drive heads?
Is there a way of determining if a drive is 80-track versus 40-track?
Am I overthinking this? I'll only be travelling about ten miles, and I plan to bring a lot of soft bedclothes to wrap it all in, so should I just not bother with the idea of parking the heads?
Any information would be massively appreciated, thanks.
Reply 1 of 27, by PD2JK
You could create a few disks, one formatted as 40 track and the other 80. Create a boot disk with park.com on it. Maybe a spare or two.
Chances are that park.com is located on the hard drive as well.
I read mixed experiences about shipdisk.com - I wouldn't use it just to be safe.
Wrapping the unit in blankets is a good idea.
has all kinds of stuff
Reply 2 of 27, by maxtherabbit
I've had the best results using the PARK program which is included with spinrite 2.
An XT is almost certainly going to have a 40 track drive. The only way the XT could possibly support high density 5.25 drives would be with the use of an aftermarket floppy controller as well as an option ROM, which was very uncommon for XT owners to do.
If you have a 40 track drive in your possession that is the best option. If you only have 80 track drives, they can write to 40 track disks just fine as long as the disk is either unused or bulk erased first
Reply 3 of 27, by Deunan
alfiehicks wrote on 2025-01-23, 21:21:
(...) original MFM hard drive and the seller showed it to be in working condition. I've heard that these drives don't park their heads (...)
Some do, like ST-251, most don't.
Here's a parking utility, IIRC from Spinrite II package by Gibson Research Corporation. I'm pretty sure it can be considered PD at this point. Works for me but I've noticed Norton Cache in its default configuration can unpark the heads a second or so after the program has been run. So don't use NCACHE before transport, preferably boot from clean DOS floppy and run PARK from there. Smartdrv seems OK but I wouldn't risk it either.
Not sure about original IBMs but clones (late 286 and newer) have BIOSes that will detect 360k drive by stepping it over 42 cylinders. That option is called Floppy Seek on Boot. So if you set the drive to 1.2M and it's actually a 40-track 360k one BIOS will report FDD error.
Nope. Park the heads. It might seem like it would also be best to have the HDD placed vertically but don't do that. It'll work with NECs that have head lock mechanism but in Seagates the head will just move due to bumps and vibrations and might unpark and scratch the surface. The heads on these disks are quite big and their mass can cause damage to platters if dropped for example. So if you want to make sure the HDD survives the potholes cushion the whole PC as best as you can - that's in addition to parking the heads.
Reply 4 of 27, by alfiehicks
maxtherabbit wrote on 2025-01-23, 22:12:
It's got a single half-height drive, might that be an indication of it being an aftermarket high density replacement? There's also what appears to be a card with a female DB-25 connector in the 8th expansion slot, and I know that slot is slightly weird. Could it be a floppy controller card that supports an external drive?
Either way, I suppose I should target the lowest common denominator and just write a 40-track disk, since as far as I've gathered, it'll still be readable on the off chance it does happen to be an 80-track drive.
Reply 5 of 27, by alfiehicks
Deunan wrote on 2025-01-23, 22:22:
What do you mean by having the HDD placed vertically? Do you mean to say that putting the machine on its side as if it were a tower is a bad idea for transportation? Or are you saying that I should do that?
Reply 6 of 27, by Deunan
alfiehicks wrote on 2025-01-23, 22:41:
I'm saying don't do that. It might seem like a good idea but it's not unless you know enough about that particular HDD type to be certain the heads won't move.
As for the female DB25 it's probably serial port, old style connector.
Reply 7 of 27, by DaveDDS
The standard FDC used in an XT couldn't read/write HD disks ... so it's likely a DD disk (360k for 5.25, 720k for
3.5).
80 track DD 5.25" drives do exist, but they were not normally used in a PC.
Virtually all 3.5" drives are 80 track - both DD and HD editions exist.
Most OS's can double-step 80 track drives to read/write 40 track diskettes (you normally
only see this on 5.25" drives) be aware that the actual tracks are thinner on the head of an 80
track drive, and if you use media formerly written 80-track, then re-written 40-track on an 80-track
drive (with double stepping) ... it can cause reliability problems when read on a 40-track drive as it's
fatter head may see interfering partial signals from the now-unused extra thin tracks in between the ones
in use - best to use never written or bulk erased diskettes when writing 40-track images in an 80-track
drive which you might need to read back on a 40-track drive!
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 8 of 27, by jakethompson1
You might consider whether any tantalum capacitors will blow and possibly freak out the seller vs. being more careful with the drive
edit: Never mind, you said it already works
Reply 9 of 27, by alfiehicks
jakethompson1 wrote on 2025-01-24, 01:12:
I'm still prepared for it to potentially go bang; always the case with old stuff. I'll warn them about it, too.
Reply 10 of 27, by alfiehicks
DaveDDS wrote on 2025-01-24, 00:25:
I assume you mean they were not normally used in this generation of PCs, right?
Reply 11 of 27, by alfiehicks
Deunan wrote on 2025-01-23, 22:58:
Great, thanks. As for the monitor, I would imagine conventional wisdom applies - screen facing down to avoid snapping the neck - but if there's any special care instructions then I'll be grateful to know.
Reply 12 of 27, by Deunan
alfiehicks wrote on 2025-01-24, 06:23:
Yes, that is preferable. Each positon has its pros and cons:
- on the mount, standing: serious shakes / deep potholes can sometimes cause enough stress on the neck (via the neck PCB or yoke) to kill the tube.
- face down: any dirt (mostly something flaking off the internals) can get wedged in the shadow mask, causing dead spot.
- face up: dirt can foul the guns, causing bad emissions and very poor picture (or just one of the colors)
All in all though face down is the safest, but if the monitor is relatively small (up to 15" CRT) and you can't fit it in the car face down for some reason, have it standing upright but not in the trunk. Or flatbed. Put it on one of the seats.
Obviously if somebody rams their car into yours all bets are off, but then the monitor will probably not the be the most imporant thing to worry about.
Reply 13 of 27, by alfiehicks
Deunan wrote on 2025-01-24, 14:45:
Yes, that is preferable. Each positon has its pros and cons: - on the mount, standing: serious shakes / deep potholes can someti […]
Oh, whoops, I thought I stated what type of monitor it is - that's why I was wondering about special considerations. It's an IBM 5151 monochrome display, so there's no shadow mask for dirt to get wedged in, right?
Reply 14 of 27, by Deunan
alfiehicks wrote on 2025-01-24, 15:22:
Correct, monochrome CRTs don't require the gun spots separated for color purity so there is no need for any kind of mask. That also makes them brighter at lower HV and usually longer lasting, but that also depends on the gun quality. Sadly some people run them very bright (perhaps due to ambient light) and that can result in burn-ins. Don't leave it on with one pattern, use screen savers and/or cycle the contents.
Anyway, for mono CRT the face down is not an issue.
Reply 15 of 27, by DaveDDS
alfiehicks wrote on 2025-01-24, 06:18:
No, 80-track DD 5.25" drives were not generally used in any generation of PC.
80-track 5.25" drives used on AT+ PC's are/were HD (1.2m) - an 80-track DD drive
is 720k - fairly common in 3.5" ... but quite rare in 5.25"
I do know that they exist... while developing ImageDisk I sought to get at least one of
every possible drive type that could interface to the Nec765 FDC (the standard on a PC)
It took me a while but I did find one (and only one), a Teac FD-55F (which I still have).
PS: The reason 80-track 5.25" HD often appeared on/since the AT and not on the XT
is because the drive rotates at a different speed than DD drives (360rpm instead of 300rpm
- more like an 8" drive). To handle this and maintain DD compatibility the FDC has to be
able to transfer data at two different rates (500kbps for HD and 300kbps for DD-in-HD
- a standard DD(only) transfers data at 250kbps. The AT+ FDC implements all three rates
since you could still use DD drives on an AT.
Reply 16 of 27, by alfiehicks
Sorry, I forgot to ask earlier - is the PARK.COM file that you provided made for a specific version of DOS or will it run on any version?
Reply 17 of 27, by Deunan
IIRC I've run that on DOS 3.3, 5.0 and 6.22 and it always worked properly. As for DOS 2.0 or earlier I can't say...
Reply 18 of 27, by alfiehicks
Deunan wrote on 2025-01-29, 17:46:
Thanks. Out of curiosity I ran it on a 486 with DOS 6.22 and it seemed to run fine. I've now written a minimal 6.22 boot disk with nothing on it besides PARK.COM, and I bought a proper Shugart 360k drive to write it on. I'll be collecting the machine tomorrow, and I am fully prepared. I just need to hope none of the capacitors decide to go boom when I power it up.
Reply 19 of 27, by alfiehicks
UPDATE:
I got it home, and it works!
Also, to my great surprise, 640K!
I nearly shat myself when I had it running at the seller's house: the power suddenly went out, and I thought it'd died and tripped a breaker, but he said they'd had a powercut about 10 minutes before I arrived, so it must have just been another one. For some reason, though, it wouldn't boot from either of the disks I wrote - thankfully it could still run PARK.COM, and I didn't see Norton in a quick dir of the hard drive.
Regardless, I have it now, and it works. Thank you so much to everyone who helped, it's really been invaluable.
