First post, by flightjunkie
Howdy. So I was testing this "https://theretroweb.com/motherboards/s/ecs-n2u400-a" motherboard yesterday, and initially everything was looking good.
It would post with both an AGP and PCI graphics cards, and it seemed to have no issues save one. I noticed that the DDR memory I had installed was showing in the boot screen as 200mhz instead of 400. Going in the bios I noticed that the available FSB frequencies were from 100 to 200 instead of 200 to 400. Anyway, I set the FSB to 200, but that caused the computer to stop posting. I removed the CMOS Battery to reset the settings and the mobo would start posting again(that was before I found out it had jumpers for that), but like before, at 100mhz FSB.
After looking around for a bit I found out that this might be due to the fact that the Heatsink is not seated properly on the CPU(Mine's an Athlon XP 2000). As I was doing a general, quick test, I didn't clip the cooler on the socked, and generally I had no issues when testing other boards with different sockets. I just had it sitting on the processor. From the bios the temps were hovering around 26c to 27c. So it was pretty cool. But I thought it was something that might not be immediately apparent, so I clipped the cooler on the socket. Now I expect people here to be aware of what short of cooler the 462 takes. You really need to be careful when trying to clip it on. I did my best and the latches were in place without much fuss.
So, now it is the moment of truth. I sort the power button pins, and now.........it doesn't post at all. It just repeats a single loooong beep.
Needless to say I was certain I obliterated the Athlon while trying to install the cooler. I am still reeling after some time ago I got careless and fried another Athlon( I mean literally. It smelled and the cpu got burned)
I tried to look up what that meant, but I found conflicting info. Some said, it's the CPU others it's the memory, and I wasn't able to find a list with the beep codes for the motherboard. I tried different CPUs(a duron 800, athlon 1900 and athlon 2500. Yes, I like my Athlons), and it still gave me the long beep. Now, it would be a bummer if the mobo's busted, but I was relieved the Athlon is probably not the issue. So now I was left with the memory. I tried changing it, but the only thing I managed was to make it beep differently, one long beep and three small ones, after installing a dead stick of ram to see what it does. Still, I get the long beep on good sticks.
The Salvaged parts Rig that cost me nothing.
-QDI advanced 10t
-Pentium III 1000mhz
-SoundBlaster Live! Value 5.1 CT4830
-WD800 80gb HDD
-TwinMOS 256MB of RAM
-Windows 98 SE
Reply 1 of 3, by flightjunkie
Close the topic. I fixed it. I changed the ram to the slot that is alone. I don't understand why it worked in the wrong slot previously.
-QDI advanced 10t
-WD800 80gb HDD
-Windows 98 SE
Reply 2 of 3, by momaka
Considering this is an ECS motherboard, I strongly suggest to carefully inspect all of its electrolytic capacitors for bulging and/or leaking signs. ECS of that era regularly used OST and G-Luxon - the latter being quite crappy and regularly bulging around the CPU.
Also, you got real lucky you didn't fry your CPU. Not clipping the heatsink on a socket 462 CPU is usually deadly for it, even for a quick 1-2 second test.
Reply 3 of 3, by PcBytes
His will 99% use OST. The 462 boards from that timeframe (2003-4) started using OST on the main, moving away from G-Luxon.
