First post, by Peter Swinkels
Peter Swinkels
Offline
QBasic's PCOPY doesn't work properly with text 50 lines in text-mode. I fixed that:
Assembly:
; 50 lines text mode PCOPY substitute for QBasic.push bp ; Save previous bp.mov bp,sp ; Set new bp.push ds ; Save ds.push es ; Save es.push di ; Save di.push si ; Save si.mov cx,0xb800 ; Set bx to the first screen page's segment address.mov dx,0xba04 ; Set cx to the second screen page's segment address.mov bx,[bp+6] ; Load parameter. (0 = copy, 1 = restore)cmp word [bx],0 ; Unless parameter is zero, these addresses are swapped before copying.je SkipSwap ;xchg cx,dx ;SkipSwap: ;mov ds,cx ; Load source segment address.mov es,dx ; Load target segment address.xor di,di ; Set di to zero.xor si,si ; Set si to zero.mov cx,4000 ; Set the number of words to be copied.rep movsw ; Copy the source screen page to the target page.pop si ; Restore si.pop di ; Restore di.pop es ; Restore es.pop ds ; Restore ds.pop bp ; Restore bp.retf 2 ; Return and remove arguments from stack.
QBasic demo:
DEFINT A-ZCLSWIDTH 80, 50OPEN "PCOPY50" FOR INPUT LOCK READ WRITE AS 1CLOSE 1OPEN "PCOPY50" FOR BINARY LOCK READ WRITE AS 1PCOPY50$ = INPUT$(LOF(1), 1)CLOSE 1PRINT STRING$(4000, "*");SLEEP 1DEF SEG = VARSEG(PCOPY50$)CALL ABSOLUTE(0, SADD(PCOPY50$))CLSSLEEP 1DEF SEG = VARSEG(PCOPY50$)CALL ABSOLUTE(1, SADD(PCOPY50$))END
My GitHub:
https://github.com/peterswinkels
