First post, by Klankins
- Newbie
I'm having a bit of an issue trying to figure out how to setup plop boot manager. Maybe I am doing this completely wrong or just missing something.
I have 3 physical HDD in the system. One with XP, one with Vista, and one with Win7. I had written the plop 5 iso to a USB stick and set it to boot USB first in the BIOS.
That all works. Plop boots automatically and sees the drives but I don't have any way to edit the drive info. When it loads it looks like this.
HDA-Part 1
HDB-Part 1
HDC-Part 1
HDD-Part 1
HDD-Part 2
Floppy
CDROM
USB
The settings option is grayed out and says I can't save when I select it.
What I would like to do is rename the drives with what OS is on each one. It did not look like there was a way to set the drive names in the plop rom configuration utility and it sounded like there was a way to create profiles but I could not find any information on what the format of the profile file is.
Was I supposed to install plop to the USB stick rather than just write the iso to it with rufus? Anyone have any experience trying to set plop up like this?
