First post, by kotel
Hi,
Recenlty I've repaired my FX 5700 ultra which had an broken FDD339 mosfet and an KA2 diode. Made sure thing else was broken (only chips in the 3 corners on the die). Replaced them and powered the card on.
The booting process was surprisingly smooth. No artifacting, no freezing. Then I launched 3dmark03 with no fuss. Then I did a reboot after the stress tests.
I was greeted with artifacting on the loading screen on XP. After sometime it went away, so I stress tested the card again. No issues. So I reboot again aaaand..... same artifacting.
I also noticed that the resolution settings weren't kept and the performance was kinda abysmal too (maybe because it's running on AGP 4X and an p4 1.8gHz?).
I am not sure what is the issue here, so I ask if anybody knows what might be the culprit? I can't run MODS/MATS cause this card is too old.
I couldn't save them, but that doesn't mean I can't save myself!
Ready yourself!
Reply 1 of 4, by myne
I believe there was mats/mods for very ancient cards - and it ran on dos
drop memclock. See if it helps.
If no, drop core clock.
I built:
Reply 2 of 4, by kotel
myne wrote on 2025-01-28, 09:53:
May I know how to? Afterburner doesn't seem to work on xp, even the version MSI says that does.
Ready yourself!
Reply 3 of 4, by myne
Coolmods reg key still floating around?
I built:
Reply 4 of 4, by momaka
ATITool might work too, despite being only for ATI cards... at least I remember using it on several nVidia video cards, if my memory serves me right.
