First post, by Kampfkoloss
- Newbie
I have a very nice Slot 1 machine in an old Siemens OEM Case. For a very very long time I've been looking for a slotket to expand upgradability. Unfortunately I've hit a roadblock, I can't seem to overcome. Maybe the experts here on the forum could share their insights:
Are there any slotkets with Coppermine-Support that are (this is very important) not taller than 6,5 cm (~2,5 inches)?
The PSU and its shroud won't allow anything taller to fit. And 6,5 cm is the absolute maximum with only a hair of a tolerance 🙁 I can't even put back the retention clip on the cpu then^^
I'd really like to look for one with specific model numbers, because they are not too hard to find here (the EU) but either they are 7 cm or taller and/or only support Mendocinos 🙁
Changing the case would be painful, because it is the original I have found with this system. So it would be difficult for me, but if all else fails, I'd consider it.
Thanks!
(\__/) This is Bunny. Copy and paste Bunny into your
(=’.’=) signature to help him gain world domination!
(“)_(“)
