First post, by johnnybargeld
Hello, I have coded a DOS / Windows launcher for myself. It is comparable to D-Fend Reloaded but with significantly fewer functions. The programme is now finished. Maybe the programme is useful for one or the other, which is why I am making it available here. I have no plans to develop the programme any further... The functionality is actually relatively simple: In the settings you enter the path to DOSBox (it also works with DOSBox-X with some exceptions) and other settings. In the main view you can add programmes (via button or drag / drop). The interface is in German!
Current Version = 0.8.8.7
ONE MORE NOTE:
The icons used are from www.FLATICON.com
Icons made by ‘Freepik’ from www.flaticon.com
