DustyShinigami wrote on 2025-01-30, 13:28:
I did see this one on Amazon - https://www.amazon.co.uk/AstroAI-Digital-Mult … tag=snxgb313-21
Very basic. I don't think I'll be going down the rabbit-hole with any fancy ones, to be honest. ^^; I've still yet to get my head around the basic functions and readings 🤣.
Looks reasonable for the price. I don't know that brand, but most of the cheap one are good enough for basic
testing...
I did see on the specs. that it uses a "Lithium Metal" battery - depending on the exact type it could be hard to find/
pricey to replace - but you shouldn't need to replace very often.
I didn't see what the LCD is, but from the photos it looks to be a 3-1/2 digit (1/2 means the extra lead digit can only
show '1') - the most common type, you'll notice that most of the ranges that can be selected are 2...
The meter will be able to display -1999 to 1999 (insert the decimal point for the scale position)
for example, the 20v range will measure from -19.99v to +19.99v
It has limited AC capability ... just 200v and 600v (good for us and european AC) - would be nice if it had AC amps,
which would be handy measuring line current draw - but that won't be essential for most of what you will likely want
it for.
A couple of "extras" you may find useful:
It has a 10a scale - many little cheap ones can't go that high, and 10a will be enough to check the power draw of most system
rails (high-end gaming rigs with video may draw more)
It has a 200ua scale, which will let you measure very low currents -199.9 to 199.9 microamps.
This means you should be able to see draw of 0.1-0.2 microamps. (induced currents in lines etc. often cause the
lowest digit to bobble a bit in very low ranges... but you should be able to tell if it's bobbling more to one side
that true no-current (hold the leads together) - this could be useful when trying to see if there's much "power
off" draw on something like a CMOS RAM backup battery!
The fact that it has a diode test setting means it can put out enough voltage to cause a diode to conduct
in forward direction (typically >0.7v) the ability to test diodes can be very useful when finding problems in
power supplies.
The Continuity setting means it will make a noise if the leads are connected in that setting.
Very useful when you are tracing circuit connections - not having to look at the meter to see if
there's a connection.
Hopefully the above isn't a bunch of "boring stuff you already know" - I get the impression that you may not have
had/used such a device before and want to let you know a couple things it might do that may not be obvious.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
