First post, by nickshanks
Hello,
I have a Toshiba Portege 7020CT running Windows 2000. While this laptop supports it, it is not 'period correct' so I'd like to try and put Windows 98 on it as it came from the factory. According to the spec sheet (https://content.us.dynabook.com/content/produ … tege_7020ct.pdf) it should come with a "Windows 98/95 Configuration Builder CD".
Does anyone have this CD, if so do you have an ISO for it? I know this is probably a long shot but worth a try.
Thanks!
