First post, by Duffman
I'm wondering, can I flash a BIOS from a different motherboard if they have the same chipset?
For example, if I flashed a BIOS from an ABit AB-VH6-II onto a Gigabyte GA-6VXC7-4X - because the ABit has Softmenu III and a configurable PCI routing table, and because they have the same chipset.
What are the odds it will work?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 1 of 8, by analog_programmer
The odds are 50:50 - either it will work or it won't 😀 I have my doubts if this will work because of SW1 and mostly SW2 hardware DIP switch settings for CPU frequency and multiplier on the Gigabyte GA-6VXC7-4X mobo, but if you have a dedicated EEPROM programmer, nothing prevents you to try it.
P.S. The south bridge chips seem to be different (VT82C686A vs VT82C686B) and this also will be a problem. Also Gigabyte board lacks any onboard AC'97 codec (this probably won't be a problem).
P.S.2: VT82C686B southbridge supports UDMA-100 mode, while VT82C686A supports only UDMA-66. I have no idea if they have other differences.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 2 of 8, by PC@LIVE
I don't think that having the same chipset is necessarily the same everything else, and so it works, I can say that same MB same model and same chipset, but with different SB, it doesn't work, so you should check before all the chips match, not just the chipset.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 3 of 8, by zyga64
What PC@LIVE said ! ^^^^
In general: In addition to the chipset itself, there are also circuits for setting the voltage and frequency, as well as a hardware monitor (if any), etc.
Those are non-standardized.
However, it is safe to assume that this approach can be used for 486 and below boards.
8088@8 /640k /Genoa CGA /TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 4 of 8, by analog_programmer
zyga64 wrote on 2025-01-31, 13:03:
I already did this once with slot 1 boards, but finding a matching BIOS for north bridge, south bridge, I/O chip, etc. is harder than for s.7 boards or older.
Reply 5 of 8, by myne
The important thing for softmenu is the clock generator.
You'll need to compare the datasheets for both of they're not the same.
The simpler way is softfsb.
If you want voltages too, you'll need to look at the vrm controller.
And both need to be connected to the smbus or it simply won't work.
I built:
Reply 6 of 8, by Duffman
Oh, I missed that the southbridge chips were different. Thanks for spotting that!
I suppose it would be a good idea to keep the original BIOS on it's own chip and have a separate chip for other BIOS's that I want to experiment with.
CPU: Ryzen 9 5950X
Reply 7 of 8, by myne
analog_programmer wrote on 2025-01-31, 12:44:
686a/b are pin compatible. Most likely registers too with the possible exception of udma6 register settings.
Ata100 is the only difference I noticed.
I built:
Reply 8 of 8, by analog_programmer
myne wrote on 2025-01-31, 15:42:
Thanks for the confirmation 👍
Duffman wrote on 2025-01-31, 15:00:
Yep. Especially if you can't easily flash the chip with the working BIOS.
