First post, by DayDreamer
Hi, first post. I registered here because when searching for answers to other questions---they frequently were found here.
I'm working on a DOS PII machine (not built yet, still hunting for the parts I want as parts allow) and after that, I would like to build a 486DX machine and am even considering at some point a 286 and/or an 8088.
CRT monitor are in high demand so I thought I should use a KVM with these systems.
It looks like the "Belkin Omni View 4 Port PS/2 Keyboard Mouse Monitor Sharing Switch F1D066" would allow sharing the same monitor, keyboard, and mouse between multiple systems but while it supports the pre-PS/2 keyboard and mouse, I'm unsure if it will convert a PS/2 keyboard and mouse to the serial devices used by them on the 8088 systems.
Does anyone here happen to know?
Also, is there a better KVM for this purpose than what I mentioned?
It's doubtful I would ever have more than one system booted at the same time but not impossible.
For my initial PII based DOS machine (using a 440LX chipset motherboard, I'll leave the supply of better 440BX motherboards to people wanting to run Windows > 3.11) I don't need the KVM and will likely just use my old Dell monitor that supports SVGA input, but I do CRTs are better at resolution switching than a flat-panel (best at its native resolution) and will be building a 486DX (largely for MechWarrior, one of the few non-text based games I enjoyed). A 286 and/or 8088 system is less likely, but I want the option open.
Thank you for suggestions.
