First post, by Zork
Hi, I've used DOSBox for well over a year now, and it's a great program. Although I do have one question. Is it possible to switch DOSBox's screen size from 640 * 480 to something such as 320 * 200 or 1024 * 768. Is there anything I can edit in the .conf file to change this?
"You have entered a dark place. You are likely to be eaten by a grue."
Reply 2 of 2, by eL_PuSHeR
Rank Moderator
Moderator
Edit your dosbox.conf and look for a line containing....
fullfixed=true {must be true}
fullresolution=1024x768 {change to the resolution you want, but i think less than 640x480 is not supported. Correct me if I am wrong.}
PS. Start by reading THE README FILE.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
