First post, by vermillion
Hi, i have two Neoware Eon thin clients, both with faulty power supplies. one clicks but will not start and the other just would not turn on after just switching off and will not work again. I have checked they are receiving 240v and that the fuse in the power supplies are good. no visible bad caps in either. The clicking one i may try to recap and see if it starts. But i would like to ask if i could replace the power supply with a power supply listed as " 12V 300W 24 Pin ATX Switch PSU For HTPC POS Mini ITX High Power Supply Module " if i spliced on the power connector to the motherboard.
Original specs are:
SP9919B
1.0 INPUT SPECIFICATIONS
1.1 AC VOLTAGE:
THE RANGE OF INPUT VOLTAGE IS FROM 90Vac TO 264Vac
1.2 FREQUENCY:
THE RANGE OF INPUT FREQUENCY IS FROM 47Hz TO 63Hz
1.3 AC CURRENT:
THE MAXIMUN INPUT CURRENT SHALL BE LESS THAN 1A
1.4 INRUSH CURRENT:
THE INRUSH CURRENT WILL NOT EXCEED 30A AT 115Vac INPUT OR 60A AT 230Vac
INPUT, COLD START, and 25℃
2.0 OUTPUT SPECIFICATIONS
2.1 OUTPUT REGULATION, RIPPLE AND NOISE, CURRENT:
OUTPUT VOLTAGE OUTPUT RIPPLE LOAD
VOLTAGE REGULATION TOLERANCE &NOISE MIN MAX
+5Vdc +/-5% +4.75V~ + 5.25V 50mVp-p 0.50A 3.5A
+12Vdc +/-7% +11.16V~+12.84V 240mVp-p 0.00A 0.5A
-12Vdc +/-10% -10.80V~ - 13.20V 240mVp-p 0.00A 0.1
Possible replacement specs:
Specifications:
Input voltage: 12V DC (11.4-12.6V)
Input Current: Max. 25A
Output Power: 300W
Power Efficiency: ≥ 85%
Applications: MINI computers, HTPC, POS, Digital Set-Top Boxes, ITX Case, Network Servers, AD Machines, Bank Terminals, Mining Machines, etc.
Working Temperature/ Humidity: 0℃ ~ 55℃/ 45% ~ 75%
Storage Temperature/ Humidity: -40℃ ~ 70℃/ 10% ~ 90%
Atmospheric Pressure: 86Kpa ~ 106Kpa
Module Board Size: Approx. 154 x 35 x 15mm/ 6.1 x 1.4 x 0.6in
Package includes:
1 x 300W Power Supply Module
1 x 24Pin to 20Pin Cable
1 x DC Input Cable
1 x AUX Cable
Package List:
1 x DC Input Cable
1 x AUX Cable
ps: unsure if i am allowed to upload possable replacement item photos from ebay.
