X-fi platinum problem
First post, by ciornyi
Hello ,
Recently i rebuild my xp machine and swapped audigy 2 with X-fi platinum. This card i bought new around year 2006 . Since then X-fi moved to every new system i build until i finally bought motherboard without pci slot few years back. But no matter what system it has been inserted it behave same thing . Randomly card dissapears from windows , It didnot showed in device manager . Restart doesnt helped aswel as turning off .Switching to another pci slot is only way it worked . In windows 10 also was another issue it might randomly make pitch sound and also stoped produce any sound but it was fixable just by switching to another sound mode. Anyway since this card is going to stay in windows XP system id like to get it fixed if it possible . Model of the card is SB0460.
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3 900/256mb/SB live/3dfx V3
Win Me: Athlon 1333/256mb/Audigy2/Geforce 2 GTS
Win XP: E8500/4096mb/SB X-fi/Quadro fx 4500
Reply 1 of 5, by The Serpent Rider
Looks like it needs recapping.
Reply 2 of 5, by Repo Man11
The Serpent Rider wrote on 2025-02-13, 19:15:
I agree with Serpent Rider. I've two of these that do not work - one won't be detected at all, the other will be, and the driver will install, but then I get the message "This device cannot start (code 10)." Both are in my "When I get around to it" pile.
Reply 3 of 5, by shevalier
yep
this 3 cap is critical for digital part of X-Fi
big - something like "820+" u* "3.3+" V "old type" polymer cap (not modern super-ultra-mega-LowESR, approximately 20mOhm)
around 1117 regulator - 10~100uF 10+V polymer cap
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 4 of 5, by ciornyi
Thank you for your reply ,i not ready for recap yet so i just cleaned contacts , will see how it goes .
PS those 4 caps looks normal , but im noted , they will be replaced first , when i get time.
Reply 5 of 5, by Repo Man11
ciornyi wrote on 2025-02-14, 15:10:
One of mine (the one that now gives the "Code 10") was received in a small lot of parts, and was initially not detected at all. Though it wasn't bulged like the one in the above photo, I had read a guide for these cards that indicated that capacitor is often an issue, so I replaced it. The fact that the card is now detected and will install the driver shows that it was a problem, but obviously not the only one, so my plan is to replace all of the rest.
