First post, by DosFreak
I only have the demo of this game and have never really played it so I'm not too sure of the issue that is described but I plan to check it out tonight. Was wondering if someone else has the game and is familiar enough with the game to confirm this issue?
Here's the link:
http://www.thespacerace.com/forum/index.php?t … g9266;topicseen
I'm having two separate problems when I play in DosBox 0.63, and I'm hoping someone can help. The first problem is that the game […]
I'm having two separate problems when I play in DosBox 0.63, and I'm hoping someone can help. The first problem is that the game seems to hang at certain spacecraft checks during missions. The example that's plaguing me the most is right after the mid-course correction burn on the lunar probe landing. This occurs even with movies and sound off, and it happens every time.
The second problem, which is less severe, is that ioctl doesn't work for me. If I use the ioctl switch for the CDRROM, the game and the whole computer lock up when it first tries to play video.
Does anyone have any ideas?
--Jonathan
I sure do wish people would post their game problems with DosBox on the actual DosBox forums....guess that's expecting too much.
Make your games work offline
