First post, by GALAHs
I have two PCIE --> PCI adapters I bought to get SoundBlaster cards working on two AM4 platform PC's.
The Startec one with the Pericom - PI7C9X118SL bridge chip seems to be working ok with a SoundBlaster Live 5.1 and Audigy 2. It's just a shame its so expensive.
A generic adapter I purchased off ebay that uses ASM1083 bridge chip has had nothing but issues.
It wont even let me boot the PC with the Audigy fitted. The Soundblaster Live boots, drivers install ok but the sound is really distorted.
I'm not sure if I am just wasting my time trying to get the generic adapter to work.
Anyone have any experience using PCIE-PCI adapters for SoundBlasters.
Reply 1 of 10, by Dothan Burger
Maybe the ASM1083 adapter is damaged. I've tested a PLX based Amfeltec adapter and an Ali Express ASM1083 adapter and haven't any issues with SB lives in either.
I've read of some having issues with ASM1083 devices if they had PCI-E power saving features enabled maybe that's something to look into.
Reply 2 of 10, by The Serpent Rider
You need -12v rail for Sound Blasters to work, so cheap adapters won't work without additional modding.
Reply 3 of 10, by Dothan Burger
The Serpent Rider wrote on 2025-02-16, 21:25:
This is the Ali Express adapter I used and it works great for sound Blaster live. I paid about $40 more than the already super expensive price for the Amfeltec because it had -12V and I'm not sure it made any difference.
Ali Express single PCI adapter $16.
Amfeltec dual PCI adapter $299
Reply 4 of 10, by GALAHs
The cheap card had a molex cable which I did plug in???
Dothan Burger that adapter looks ok. Does it connect to a PCIE card with a USB cable?
Also what power adapter does it use? A floppy disk power connector?
Reply 5 of 10, by Dothan Burger
The USB cable just carries the PCIE lanes minus the power to another PCIE adapter, like a mini PCIE or M.2 adapter. The Power is supplied by a standard 12V AC adapter.
This setup worked great for my Soundblaster live on a first gen Core i5 ITX board I'm working on.
Reply 6 of 10, by mln
I believe this is not true.
Asus H61M-K + SB Audigy 2 (SB0204) works fine with this cheap ASM1083-based PCIe-PCI adapter:
The attachment Untitled.jpg is no longer available
Of course you need to supply power with a floppy disk power connector.
Reply 7 of 10, by Azrael128
Sorry to unearth a thread a several months after the last post, but I'm currently getting massive headaches getting an Audigy 2 ZS to work on AM5. Has anyone tried this on something like an X670/E motherboard and has a bridge confirmed working?
So far I tried:
- Pericom PI7C9X111SL - undetected (was detected on some of my slots in my previous, X570-based motherboard)
- PLX PEX8112 - detected but sound quiet and distorted, and card behaves erratically.
Anyone of you had better results with a specific adapter?
Reply 8 of 10, by myne
Wouldn't hurt to check voltages, and it never hurts to add another earth strap from card to the case to make sure it's good.
I built:
Reply 9 of 10, by Dothan Burger
Azrael128 wrote on 2025-06-25, 04:00:
Sorry to unearth a thread a several months after the last post, but I'm currently getting massive headaches getting an Audigy 2 […]
So far I tried:
Maybe it's the AMD chipset giving you issues. I'm using the PLX PEX8112 with and Audigy and a PCI 3Com on an intel QM57 chipset.
Reply 10 of 10, by Azrael128
Dothan Burger wrote on 2025-06-25, 11:23:
It probably is, the Pericom-based adapter worked on an X570 motherboard just a few weeks ago, but I think some bridges (and some adapters using this or that bridge) may be more suited to modern platforms than others. After all, there is already a significant difference between the Pericom bridge and the PLX one, though even the PLX one doesn't yield satisfying results.
I'm not surprised that you got it working with Intel, it seems Intel-based motherboards are much better at dealing with legacy PCI. Unfortunately, I went the AMD route and it's too late to change course so if anyone got any good result on AM5, I'm all ears.
