First post, by Oerg866
Hi,
I'm trying to build a weird Athlon XP + Voodoo 2 (usually SLI, but the FBI on one of the cards has died so only one at the moment) system, but I can't get the 3DFX version of Tomb Raider to run on it at all.
If I use TOMB3DFX.EXE, I lose video signal immediately after starting the executable.
If I use TOMBRUSH.EXE, the game plays the FMVs, and then the menu seems to run, but I just get a black screen. There is a monitor signal coming out of the Voodoo, but it's completely black. The system is not hung and I can Windows-Key my way back to the Desktop.
The V2 card is completely fine in the system otherwise.
Same results in pure DOS.
I transplanted the V2 card to a i440BX system and got the same result, then I asked Computerguy096 and it worked for him, until he tested a higher clock speed, and it seems at around 450-500MHz it stops working.
I confirmed this by downgrading the system to a Celeron 366, then I was able to play the game just fine.
Any ideas? Is this a known problem? Couldn't find anything on a brief google.
EDIT: Just realized I may have posted in the wrong subforum, feel free to move.
Thanks,
Eric
Reply 1 of 5, by bloodem
Yes, it's a known problem, but I was able to make it work on a fast Athlon XP system by decreasing the CPU speed as much as possible (6 x 100 MHz) + using the original executable for Voodoo 1 with the following environment variables:
SET SST_GRXCLK=90
SET SST_FT_CLK_DEL=0x4
SET SST_TF0_CLK_DEL=0x6
SET SST_TF1_CLK_DEL=0x6
SET SST_VIN_CLKDEL=0x1
SET SST_VOUT_CLKDEL=0x0
SET SST_TMUMEM_SIZE=2
SET SST_SCREENREFRESH=60
SET SST_RGAMMA=1.30
SET SST_GGAMMA=1.30
SET SST_BGAMMA=1.30
SET SSTV2_FASTMEM=1
SET SSTV2_FASTPCIRD=1
SET FX_GLIDE_ALLOC_COLOR=3
Having said that, it will definitely be hit & miss, I don't guarantee that it will work on EVERY socket A system.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 2 of 5, by Gmlb256
As bloodem said, it is a known problem. Depending on the platform, slowing down the CPU (setting the FSB to 66 MHz, reducing the multiplier, .etc) and applying the essential environment variables would help.
This is because the original 3dfx version of Tomb Raider (TOMB3DFX) uses Glide 2.1.1 which is speed sensitive, was designed for the original Voodoo Graphics card and whose DOS version of the API gets integrated into the executable. The Voodoo Rush (TOMBRUSH) version uses the external GLIDE2X.OVL file and shouldn't have this kind of problem. The only downside with this version is the lack of shadows.
Reply 3 of 5, by Oerg866
Sadly the rush version is having this problem 🙁
Is there maybe a Glide2x OVL file that is patched?
Reply 5 of 5, by Oerg866
Oh that looks helpful, thanks! One moment 😀
