First post, by bimole
Hi,
I have a non-posting MS-6309 V5 mobo...
After checking and fixed some things (bad VRM voltage due to broken resistor) it is still non posting : 4 red diag LEDs, no beep, nothing.
I've tried with/without CPU, RAM, GPU and even the BIOS chip, it's always the same result.
I'm sure I'm using working CPU, RAM, GPU...
I am now suspecting the BIOS.
I backuped the BIOS chip with my programmer (T48) and I also dowloaded the different BIOS versions here : https://theretroweb.com/motherboards/s/msi-ms-6309-v5.x#bios
I tried every single BIOS versions and even reflashed the backup. Still nothing.
I would like to read the BIOS rom with AMIBCP. I tried almost every versions from 3.13 to 4.55. I always get the same error "couldn't open this file" (I renamed the BIOS rom files with the .rom extension).
Same with backuped rom or rom from The Retro Web
What's wrong with these MSI BIOS files ?
Cheers,
JB
