First post, by kotel
Hi,
As the title says I need some help getting this game to work on w7 and above.
What I've tried:
Installing it on XP, then patching (works on xp), then moving it to w7 machine
Installing it on w7 and patching using the 2.0.4 patch by EA
Setting compatibility mode to xp sp1 on w7 and renaming game.dat to .exe (this has worked for normal generals)
But to no avail. Game still crashes before it goes to the cnc splash screen. No errors, only when I launch the game normally (no admin privileges). Any ideas?
"All my efforts were in vain...
Let that be my disappointment."
-Kotel
Reply 1 of 7, by feda
Is this the original disc release?
Did you apply a crack?
The game is infected with SafeDisc which won't work on Vista or later.
Reply 2 of 7, by kotel
feda wrote on 2025-02-17, 15:00:
This is the original release, atleast as I recall.
Couldn't find any cracks online, just gentool and other gppatchers that only work on w10/11.
-Kotel
Reply 3 of 7, by feda
Try gamecopyworld.
By the way, there is no "2.0.4" patch for Generals/ZH, so I don't know what you've installed.
Reply 4 of 7, by kotel
feda wrote on 2025-02-17, 15:44:
Try gamecopyworld.
All the links are dead, even on web archive.
I think I got the 1.0.4 and I'm misremembering it as 2.0.4 patch.
-Kotel
Reply 6 of 7, by kotel
feda wrote on 2025-02-17, 15:58:
kotel wrote on 2025-02-17, 15:53:
Try gamecopyworld.
Nope, works fine. Even with uBlock on.
Now I get serious error even with the options.ini patched and compatibility mode to xp sp1/sp3/vista. Any ideas?
-Kotel
Reply 7 of 7, by Dancsi40
the retail version is protected with safedisc 2 that doesn't work on windows vista and above.
you better get the C&C The Ultimate Collection, it constains all games and works with Win7 and above.
