First post, by noshutdown
i have been running winquake for most of the time, without much experience on dos quake. now i am running dos quake on a 486 machine recently, and the video card is a cirrus5434 isa.
basic vga 320*200 mode is ok, but it doesn't detect any vesa modes at all. with univbe, only 320*200 is listed, and it turns out to be very flawed, flickering heavily with misaligned pageflip graphics.
whats wrong with that, any workaround?
Reply 1 of 13, by BinaryDemon
486 class machine with ISA videocard is a bad combination for Quake.
I don’t know why you only see one VESA mode even with univbe, how much vram does your card have?
Reply 2 of 13, by leileilol
Quake will also limit how many video modes are available if you don't have enough system memory, as the size of the surface cache will be variably larger on higher modes.
Also, Quake only works with VESA 2.0 modes when it comes to non-VGA modes available.
long live PCem
FUCK "AI"
Reply 3 of 13, by Grzyb
That ISA Cirrus most likely contains VBE 1.2.
You can add VBE 2.0 using UniVBE.
However, it's unlikely for an ISA card to support LFB - which may be a problem for late DOS games.
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
Reply 4 of 13, by theelf
anyways with a isa cars feel lucky you can use 320x200!!
try 486quake
Reply 5 of 13, by noshutdown
Grzyb wrote on 2025-02-19, 16:29:
as i said, it doesn't detect any vesa modes without univbe, and with univbe it only detects a very flawed 320*200 vesa mode. i have just swapped in a umc85c408 card for testing and it simply behaved the same.
Reply 7 of 13, by noshutdown
leileilol wrote on 2025-02-20, 02:04:
of course it doesn't - 5434 predates VESA 2.0.
this is understandable, but the rest of the question remains unsolved.
Reply 8 of 13, by Grzyb
"Quake demands VESA 2.0 with linear frame buffer (LFB) support for higher res modes" - Re: Quake won't do 640x480
On ISA cards, UniVBE does provide VBE 2.0, but without LFB.
Try VBETEST.EXE :
The attachment 1.png is no longer available
The attachment 2.png is no longer available
In theory, on machines with <16 MB of RAM, LFB on ISA is possible.
In practice - I've never seen LFB on ISA yet...
Reply 9 of 13, by noshutdown
Grzyb wrote on 2025-02-20, 02:51:
"Quake demands VESA 2.0 with linear frame buffer (LFB) support for higher res modes" - Re: Quake won't do 640x480 On ISA cards, […]
does that mean no isa cards can run quake in vesa modes?
i really don't like all those modified vga modes with odd aspect ratios. but really, even on very fast computers i would play winquake with the most simple 320*200 vga mode, blurred details seems to relieve my dizziness, higher resolutions are just for benchmarking.
Reply 10 of 13, by maxtherabbit
noshutdown wrote on 2025-02-20, 11:15:
yes
quake was released in 1996, if you were still using ISA graphics you would be laughed at
Reply 11 of 13, by Grunt
Read documentation. Use parameter -winsize X Y for literally any resolution. My favorite is 410x256 or 683x384. No problem.
Reply 12 of 13, by Grzyb
Come to think of it, LFB on ISA may be possible even with 16+ MB of RAM.
The "Memory Hole at 15M-16M" BIOS option seems to be meant for this.
Again: I've never seen LFB on ISA, but that doesn't mean it doesn't exist - I'm hereby encouraging you all to experiment!
Still, Quake was designed especially for Pentium - and I mean *true* Pentium, with its fast FPU, not for "Pentium class" CPUs of other manufacturers which were only good in integers.
And it didn't make sense to couple a Pentium with ISA graphics.
Reply 13 of 13, by Malik
486 and ISA graphics with Quake? A big no no. Especially VESA 2.0 modes on that VGA card? It's a fruitless effort. Besides, Quake was designed for Pentium and SVGA cards.
I remember Quake makes use of the Pentium's math co-processor optimally to run Quake at its best. IINM, this is mentioned in the readme file that comes with Quake.
If at all able to still run it on that system, it will be a slideshow or will produce errors as you have mentioned.
