First post, by theelf
Hi, love to listen to module music, but sadly no idea about how to create or fix them
Im using AWE32 Module Player v1.51 with a AWE64 Gold, the quality is amazing, but I have a problem.. some modules when i reproduce in a playlist, never finish, just when reach last pattern, start again
I attach to files, module1.mod is fine, when reach last pattern, just AWE32 Module Player load next song, but module2.mod, just became a loop
Any ideas if is possible to "fix" this mods are welcome
thanks
Reply 1 of 8, by mkarcher
There is a "jump to pattern" command that can be placed as "effect" into the MOD file. I'd guess, but didn't verify that your "module2.mod" has this jump command at the last row of the final pattern.
Reply 2 of 8, by Grzyb
AMP.TXT :
"all kinds of song loops can be reliably disabled - a 'must have' option for unattended playback of multiple songs"
Just find that option...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 8, by theelf
mkarcher wrote on 2025-02-19, 19:25:
Thanks a lot!!! i was reading about jump command, that is a Dxxx, and check last pattern, in hex dir 0x4330 I found0 a 0D if i change to 00, the module never loop again
thanks, now i need to find more looping mod and check if this jump is there
Reply 4 of 8, by theelf
Grzyb wrote on 2025-02-19, 19:33:
AMP.TXT :
Hi, where you read this?
Reply 5 of 8, by Grzyb
theelf wrote on 2025-02-19, 20:09:
ftp://ftp.elf.stuba.sk/pub/pc/sound/amp30.zip -> AMP.TXT
Reply 7 of 8, by Grzyb
Ah, so it's two different programs!
It may be a good idea to try the AMP30 - it's newer, hopefully better...
Reply 8 of 8, by theelf
Grzyb wrote on 2025-02-19, 21:13:
Hi, i already tried AMP30 and yes, works fine with this "loop" mods, i preffer AWE32 Module Player because GUI and options, much better, but if i cant solve in a easy way the looping problem, i will use AMP30
The modules sound amazing in my AWE GOLD, i dont miss my a500 for modules!
thanks!
