First post, by DayDreamer
Hi,
Do any of the PCI SATA cards work with MS-DOS 6.22 and/or FreeDOS and are bootable?
I know the PCI cards (opposed to PCI-E) are generally limited to 1.5Gbps but that's not an issue. It just seems that SATA would make both a CDROM drive easier (I already have several) as well as making a hard drive easier. I know SATA to IDE adapters exist but for example, I think the TRIM command used by an SSD doesn't work through them.
I could go the IDE/PATA to CF card route for the hard drive and find a used ATAPI CDROM drive, but if the PCI SATA cards work with MS-DOS 6.22 / FreeDOS then it just makes more sense to use one of those for a "bare metal" DOS build.
Thank you for any suggestions.
