First post, by RetroLord12p
- Newbie
Hi all, long time lurker here and having to post here as a last resort.
I've been working on upgrading an IBM aptiva 2170 to the best it can be, and just got an fx5500 in the mail a few days ago. I was hoping this would run everything I wanted it to (Mostly games up to 2003ish) but this computer has been saying fuck you to everything I try.
Specs:
Amd K6-II 533mhz (Clocking at 550mhz on this bios)
192mb Ram
AcerV75m Motherboard
Fx5500 256mb PCI
Win98SE
Extra Details:
- Tried Drivers 45.23 & 56.64, both make absolutely no difference in performance
- Tried switching PCI Irq, turning on/off bus mastering, removing Isa cards, changing slots
- No option to disable on board graphics in bios, only did so in windows (motherboard has agp instructions for integrated graphics)
- Pci Bus is only 33mhz, but even still performance is way less than half of what I should be getting
- 3DMark99 scores around 1100 - 1300 Usually
Compared to the 8mb onboard graphics, some games run a bit better, some about the same, and some even worse:
Harry Potter & Chamber of Secrets - An abysmal 3 - 6fps on all low settings
Tonic Trouble - 23 - 30fps 640x480 Medium details
Spongebob Employee of The Month - Less than 10fps (WORSE than integrated graphics)
Lego Island - Better but still has some bad fps drops at 800x600
Rivatuner overclocking also doesn't seem to provide any performance gain, and for some reason on the graphics subsystem diagnostic report, it shows the core clock at 100mhz and memory at 165mhz, even though it shows them at their normal speeds in the overclocking menu.
I've tried so many different things and spent money buying the pc, cpu, and now the gpu, I'm at my wits end 🤣. I'm trying to avoid buying another motherboard as much as possible, so hopefully I won't have to...
