First post, by Minuous
Bug report:
When I go into full screen mode, the resolution goes to 640x480 in 256 colours, and stays there permanently even after switching back, so I have to go into Control Panel each time to change the resolution back to what it was. I use CGA in DOSBox.
Reply 1 of 7, by DosFreak
Might help if you provide some info:
Operating System and Service Pack Level
Video Card
Video Card Drivers Version
Version of DosBox used
What kind of monitor being used? LCD/CRT?
When you say the "resolution goes to 640x480x256".
Do you mean the desktop resolution? Not DosBox? DosBox doesn't support 256 anyway so you must be referring to your Desktop resolution.
Make your games work offline
Reply 2 of 7, by Minuous
Video card: SiS 650_651_M760_M763_740 version 0.0
OS: Windows 98SE
DOSBox version: 0.63
Yes, the desktop setting is changed.
Reply 3 of 7, by Minuous
Standard CRT monitor.
Reply 4 of 7, by Minuous
Still getting this with the latest CVS version.
Maybe my video driver is not much good...although everything else seems to work?
Reply 5 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
try setting the windib variable before starting dosbox to see if that changes something
set SDL_VIDEODRIVER=windib
dosbox
Water flows down the stream
Reply 6 of 7, by vasyl
Is that, by any chance, Shuttle SFF PC? SiS 650 chipset is OK for desktop apps but quite buggy when it gets to DirectX. Try updating it to the newest version from SiS site -- I don't like that version 0.0, the current version is 2.21.
Reply 7 of 7, by Minuous
Setting the variable mentioned doesn't fix the problem but does change the behaviour:
Now when I try to switch to full-screen mode, the window client area goes completely black for a few seconds, then closes (without an error message).
I will look for an upgraded driver for my card.
