First post, by nclakelandmusic
Hey all, I have three Voodoo 2 cards I'm testing, and I also had the Extron VSW 2VGA in my bin, so I figured I'd give it a try.
When running the FastVoodoo2 donut demo, it won't auto switch. I have the blue jumper plugged in, which I assume is what you are supposed to use, but it only switches manually with the little front switch.
Any ideas how you are supposed to configure this thing to switch automatically? Is there a jumper block or something else I'm supposed to plug into the blue contact jumper?
Thanks!
Reply 1 of 2, by maxtherabbit
there needs to be a wire in the blue terminal block in order for it to do anything
Reply 2 of 2, by nclakelandmusic
Done, and it's working. I figured as much. Thanks bud!
