First post, by Paar
I have bought some Socket 7 boards with three Winco W-P55VT2 being among them. Visually they look OK, except one which has cache chips missing.
The attachment IMG_20250305_140045023.jpg is no longer available
The attachment IMG_20250305_140150661_HDR.jpg is no longer available
The attachment IMG_20250305_140127947_HDR.jpg is no longer available
My focus is on the other two boards with cache chips. As mentioned before they both look visually OK and I couldn't find any significant damage. Somebody did some bad solder job on the voltage regulator though so my first suspicion was that some components went puff.
The attachment IMG_20250305_140219488.jpg is no longer available
Checked voltages, crystals and bus speed, everything seems to be alright. But the northbridge of one of the boards got hot to touch after a while, signaling a short. Checked the resistance between 5V rail and GND and it was around 50 Ohms. In comparison, the other board, which doesn't have any overheating components, has the resistance in tens of kiloohms. So, I lifted +5V input legs from the nortbridge and sure enough, the resistance went to normal, at least in comparison with the second board.
The attachment IMG_20250305_140209017_HDR.jpg is no longer available
The board without cache chips has a short too, except it's the southbridge that's damaged. What I want to do is use this board as a donor and transplant the northbridge to the other board with presumably shorted northbridge. Of course I have no idea if the donor northridge is OK. I'll probably start with removing the southbridge chip from the cache-less motherboard and check if the short went away. If all resistances on power rails will be OK, I'll consider the northbridge as functional. We'll see how it goes.
The second board with cache is a mystery though. There's no visible damage, voltages and frequencies are OK, but there is no activity on data/address lines in ISA slots. They're always high, probably pulled-up by some resistors. Chipset is probably damaged too but it's not creating a short. If I'm successful in reviving the first board, I'll use it as a reference and try to diagnose the second one further.
Reply 1 of 5, by Paar
Okay, so I removed presumably damaged southbridge from the motherboard without cache chips and the short between +5V and GND went away. So I guess the northbridge is okay and I can continue with the transplant.
But man, was it annoying... The southbridge chip just didn't want to let go and PCI slots near it got burned a little. I think with that amount of heat the northbridge will get grilled. I have to prepare better strategy, unfortunately I don't have a good equipment like preheater plate or vacuum chip picker (had to get creative). I'll start with getting low melt solder, this should speed up the desoldering process.
The attachment IMG_20250305_210010078_HDR.jpg is no longer available
The attachment IMG_20250305_210000129_HDR.jpg is no longer available
Reply 2 of 5, by Paar
So I have ordered some additional equipment to help me work with the big QFP chips - vacuum picker and hot air nozzle specialized for these types of QFP chips. I'll see how it goes and maybe I'll order some preheating plate if necessary. For the time being I'll try to preheat the board with hot air and use aluminium foil for heat shielding.
It will take some time for the equipment to arrive so I'm putting this project on hold for the time being and will focus on different hardware.
Someone may wonder why I care about these boards with boring Via VPX chipset... For me it's mainly practice but to be honest, I find these boards somehow visually appealing. I don't know why. That and the manufacturer is somewhat uncommon.
Reply 3 of 5, by mockingbird
When you're blowing hot air around plastic, take some foil paper and fold it over the plastic, this helps in preventing melting.
(Decommissioned:)
Reply 4 of 5, by PcBytes
They're technically made by EPoX. I recognize their green-ish amber PCB color. I assume Winco was one of the resellers of the board, and I suspect Luckytech (SYE) was another.
Reply 5 of 5, by Paar
Yeah, you're probably right. The ISO sticker on one of the cache chips is a giveaway, it's often present on Winco, Lucky Star and Epox motherboards.
