First post, by fabiensanglard
I have been trying to make speedsys work on my IBM PS/1 2168 for a while. I came across command clcmos.
speedsys clcmos
Which seems to have helped go past the atapi freeze.
However after that my machine encountered an error "164 POST detected a base memory or extended memory size mismatch error".
And the mouse stopped working.
I ran the same command again and it fixed the machine. Problem solved but still I wonder how this command is working? I thought one was supposed to use jumpers or remove the battery to clear/reset the CMOS. Is there a software way to do that or speedsys command is mislabeled?
